Midi play thru
Midi play thru
Postby rickscarborough » Mon Mar 08, 2004 2:08 pm
I'm using OSX.2.8, G4733, Audiophile 2496, ekeys controller, Metro SE 6.1.
There is no play thru option in Digital Audio Setup with any option or in Core Audio Setup.
I can see input working on VU in Tracks window when I play the keyboard controller but hear nothing. (
I can hear the recorded track playback as well as the virtual keyboard in the "select sound for channel" window.
Please advise
Rick
rickscarborough
Postby Scoot » Mon Mar 08, 2004 2:51 pm
I assume your device is happy and appearing in the audio/midi setup of OSX and is connected to the midi interface.
Have you allocated an output to the particular controller you are using?
for example, you could play your synth and have it outputting to internal (quicktime instruments) and you would hear the quicktime instrument currently selected.
you could place a virtual instrument on a track (by dragging a VSTi plugin to the effect window of a track) and allocate an output to the VSTi (modify outputs and busses from the setup menu) and have your keyboard play it.
Postby Jerm » Mon Mar 08, 2004 3:26 pm
From the switches menu, try turning on "Automatic MIDI thru".
Postby rickscarborough » Mon Mar 08, 2004 3:46 pm
Thank You!
I thought I had read all the options. I guess I'm getting hard of looking.
Instant fix
Thanks again
rickscarborough
Postby Jerm » Mon Mar 08, 2004 4:32 pm
Save preferences to retain the auto-thru-on setting. :idea:
