Sagan Technology Metro • View topic - Playthrough LX
Playthrough LX
Playthrough LX
Postby Badeye » Wed Mar 03, 2004 1:15 pm
Hi
I'm running LX on a G4 iMac OSX 2.8. I use a iMic as an input device and everything records just fine, but I'm a bit confused about playthrough while recording - for example hearing my guitar as I record a track. I'm unable to do this at the moment. Is it a limitation of LX or my OS?
Oh, and is there a an upgrade from LX to the full version?
Badeye
Re: Playthrough LX
Postby Jerm » Wed Mar 03, 2004 3:36 pm
Badeye wrote:Is it a limitation of LX or my OS?
Both. I do not know of any program that will play through correctly on the iMic (or any USB audio device that is using the Apple Driver which disconnects the USB input from the USB output). The best way to overcome this limitation is to get a mixer and plug the input and output of the iMic into it. You can get some very decent mixers for as little as $69 or so.
Badeye wrote:Oh, and is there a an upgrade from LX to the full version?
There is not yet but we are working on it and it should show up in the store within the next week or so.
phonix micro I preamp
Postby Badeye » Wed Mar 03, 2004 6:29 pm
Thanks for getting back so quickly.
I've got (today) a "phonix micro I preamp", I'll give it a try tomorrow (late here). Regarding the iMic - don't I have to switch between input or output? Can I have both at the same time?
Badeye
Postby Jerm » Wed Mar 03, 2004 6:38 pm
You can use them both at the same time.
Re: Playthrough LX
Postby Jerm » Sat Mar 06, 2004 4:35 pm
There is now!
Users browsing this forum: No registered users and 24 guests
