Multi-tracking with SPDIF...
Postby MediaUnion » Sun Dec 14, 2003 5:45 pm
Hi,
I've been looking at the M-Audio Firewire 410 and they call it a 4in X 8out interface. They're including the SPDIF as a stereo input along with the 2 analog to get 4 in. Now I'm short on cash with the holidays, so I thought that I'd try before buying the 410 using my Audiophile USB (it has the two analog and SPDIF I/O).
When I enable the control pane to allow for spdif in the core audio, it shows 4 inputs. Check
Jumping over to Metro the port shows the inputs 1-4. Check
Will Metro support that kind of multi-track recording?
I have hooked up the digital out from my Phillips CDR870 to the audiophile SPDIF in but can't get a signal. It must be that the CDR isn't putting out SPDIF compatible digital. I have tried sending analog mic signals through the audiophile after checking the spdif in the control pane and the analog inputs stopped working.
Thoughts?
MediaUnion
Info from the Manual....
Postby MediaUnion » Sun Dec 14, 2003 6:11 pm
Sorry,
I forgot to include the text from the manual...
Active Channels & Sample Depth: Activation of the Analog and
S/PDIF inputs and outputs is done with a set of four check boxes.Two radio
buttons allow selection between sample bit depths of 16-bit or 24-bit.
These settings will interact with each other, either expanding or limiting
your Active Ports, Sample Depth, and/or Maximum Sample Rate settings.
Using the full USB bandwidth will allow for 4x4 audio streams at 16 bits
with a sampling rate of 48kHz or below.
I currently have it set at 16 bit and SPDIF in, Analog in, analog out.
Kevin :o)
MediaUnion
Postby Jerm » Sun Dec 14, 2003 6:43 pm
I have heard there may be problems with the M-Audio driver. Have you inquired with them?
With Metro, you should be able to record all 4 tracks at a time. 2 Analog and 2 digital assuming the driver allows it.
Postby MediaUnion » Sun Dec 14, 2003 8:07 pm
thanks Jerm,
I'll continue to bug M-Audio.
Kevin
MediaUnion
Postby MediaUnion » Tue Jan 13, 2004 11:44 pm
Just an FYI of what happened in the interim....
I packed the Audiophile USB away and purchased the Presonus Firestation from Musicians Friend for $499.
You can learn more at: http://www.presonus.com/html/products/firestation.html
Kevin
Media Union
MediaUnion
Postby Jerm » Wed Jan 14, 2004 2:29 pm
I am working on getting a firestation here. How do you like it?
Postby MediaUnion » Wed Jan 21, 2004 2:13 am
Hey Jerm,
I have had no problems with it. It runs really smooth, the converters are really clean, and the audio paths are so flexible that I haven't even begun to scratch the surface.
There's the ADAT Optical conncetivity and the FIREstation can be used as a line mixer without connection to a computer. There is no latency or delay between the time the signal hits the respective input and goes to the headphone/main output.
There's the flexibility of clock sync via BNC if you have a generator, mLan(your MAC via Firewire) and ADAT Sync.
The sample rates are 32, 44.1 and 48. Now I have only used 44.1 and I think that's all I really need.
The FIREstation can be serial chained (via Firewire)according to the manual but it sounds that doing so would require some attention (possible resetting preferences) as each FIREstation has a unique machine ID and matches computer preferences (panes?) by that ID.
The only suggestion I would have for ProSonus is simplify their channel names in their driver. Their port names in their driver look like this in all dialogs....
PRESONUS|mLAN-FIRESTAT|YAMAHA|mLAN-NCP01|NCP01V1.00 1+2
PRESONUS|mLAN-FIRESTAT|YAMAHA|mLAN-NCP01|NCP01V1.00 3+4
PRESONUS|mLAN-FIRESTAT|YAMAHA|mLAN-NCP01|NCP01V1.00 5+....etc
This is a great interface and I'm really happy with it.
Kevin Laurila
www.mediaunion.org
MediaUnion
Users browsing this forum: No registered users and 106 guests
