Sagan Technology Metro • View topic - Time and measures
Time and measures
Time and measures
Postby Biffer » Thu Jul 24, 2003 9:32 am
I've imported a drum file and it plays at a tempo of 120 and supposedly fits within 3 measures. However in the graphic editor it's coming in at a little over 3 measures. I can get it to fit by slowing down the tempo but isn't there a way to change the size of the measures/bars to fit the 120 tempo?
Thanks for any help.
Biffer
Postby Jerm » Thu Jul 24, 2003 10:05 am
Yes,
Drag the bar with the scale tool.
http://www.sagantech.biz/metro/help/Met01083.htm
Which is the tool that looks like a clock with arrows as shown in the the picture shown here:
http://www.sagantech.biz/metro/help/help5005.shtml
Postby Biffer » Thu Jul 24, 2003 10:22 am
Thanks Jerm. That did the trick. By the way..do you know where I can download additional plug-ins? My old sterio eq from metro 5 does not seem to work in Metro SE.
Biff
Biffer
Postby Jerm » Thu Jul 24, 2003 11:14 am
Are you using OS X or OS 9?
Postby Biffer » Thu Jul 24, 2003 11:35 am
I'm using system 10.
Biffer
Postby Jerm » Thu Jul 24, 2003 11:54 am
Under OS 10.2 there is a great graphic equalizer plug-in built-in. There is also a parametric EQ.
We will most likely release OS X compatible versions of most the Metro 5 plug-ins (including the parametric eq) soon also.
Postby Biffer » Thu Jul 24, 2003 2:32 pm
Thanks Jerm. I saw the AU graphic eq and the auparametric eq but they seemed so diferent from what I am used to I didn't mess with them. I guess I expected to see a 'treble' and 'bass' knob for starters.
Biffer
Postby Scoot » Thu Jul 24, 2003 11:04 pm
It's really funny when you drag the tool the wrong way and end up with a tempo over 400.
I hate the standard 'knob' plugins.
A graphic or a slider can just be looked at and you can see what its set at without looking for the black line on the knob or the numbers below denoting what its set to.
