Sagan Technology Metro • View topic - ASIO
ASIO
ASIO
Postby rickchaff » Mon Jul 07, 2003 6:50 pm
I have the Delta audiophile sound card and found I can use ASIO DeltaAPv3, ASIO DeltaAP, or ASIO2 DeltaAP with Metro 6.0.8.
I remember way back It was necessary to use the ASIO DeltaAP3.
My Question: does it matter which driver I use as long as it works?
I suspect ASIO2 is the best choice but don't know and would like some input...
Rick
rickchaff
Postby Jerm » Mon Jul 07, 2003 7:28 pm
Metro 6 was updated to allow different ASIO formats including PC formats (little-endian). It is probably best to use the driver that is returning audio data in its native format allowing Metro to do the conversion to big-endian. However, with that said, I do not know which driver corresponds to the native format. That information would have to be obtained from the manufacturer.
