Biffer wrote:I noticed that on the new 828 it is possible to put the signals through an effects processor and back into the 828. Can this be done on the older 828 as well?
There's not an effects loop as such. You can rig one up if you play with the input and output assignments.
and i sill don't get all the out plugs on the 828. You mentioned that you send out through 3 and 4 to your amp. Why not just go out through the two monitor plugs?
Er, after looking again at my setup this afternoon, I see that I lied
; I am using the main outs. The trick is understanding what the 828 actually does with the main outs: at any given time, they output a mix of whatever is on the 1-2 output pair plus whatever input pair is chosen for monitoring via the control panel application. The "main" and "monitor" knobs control the level of the mix on the main outs.
And you said you would use the others to go to soft synths. How does that work?
Sorry that wasn't clear. What I meant is that some soft synths let you route their output directly to an output device. Absynth is one that lets you do this. (Unfortunately, Absynth 2 with OSX support still hasn't been released. That's about the only thing I still have to go back to OS9 for.) Let's say I've got some audio tracks recorded already, and I want to record another one consisting of Absynth's output. I first record a MIDI track to drive Absynth, then I play it back. With the audio tracks from Metro routed to outputs 1-2, I can tell Absynth to send its output to some other pair, say 7-8, and it won't get mixed in at the main out. By patching the 7-8 outputs, I can run Absynth's signal through an external effect, and then back into the mixer to send back to Metro to be recorded on a new track. The 828's main outputs will give me a mix of the previously recorded audio tracks, controlled by the "main" knob, plus the processed Absynth signal, which I control the monitor level of using the "monitor" knob. (If it turns out that there's a noticable lag in the track, on account of having gone through the 828 twice prior to being recorded, I can use the Metro "shift" function to move the entire original MIDI track a few clocks to the left.)
I should mention that my monitor amp is an old Kenwood stereo receiver. (Lecture: KR-4070, 24 years old and still going strong... that's what happens when you size and heat-sink the predriver and output transistors properly.) From the Kenwood's point of view, the 828 is a recording device (one that the Kenwood's designers never thought of...
); the "record" outputs of the Kenwood go to the 3-4 input pair of the 828, and the 828's main outs go back to the Kenwood's "play" inputs. I can choose to listen to the 828's outputs, or to the source only, using the tape monitor switch on the Kenwood. That's turned out to be a handy thing for monitoring.
