Sagan Technology Metro • View topic - AU or VST ?
AU or VST ?
AU or VST ?
Postby almapercus » Wed Feb 04, 2009 12:54 am
Is there a recommandation between these plugins format?
Robert
almapercus
Postby Jerm » Thu Feb 05, 2009 12:02 pm
I tend to use AU but it usually depends on the specific plug-in. VST is mildly faster but AU let's you specify automation ranges using real values, VST is limited to 0.0 to 1.0. Also with AU you can have sample accurate automation with most plug-ins. There are probably several other subtle differences.
