Sagan Technology Metro • View topic - Metro snap, crackle, pop
Postby Krushzone » Mon Oct 23, 2006 9:57 am
Metro 6.3.6. with Tiger had been working fine. But after very recently installing Quicktime free upgrade 7.1.3 and iTunes 7,
I now experience "crackling" and "popping" during Metro playback.
(Same song files. Nothing else has changed.)
Sorry, I don't know what "version" of QT was previously active.
Funny thing is, iTunes doesn't snap, crackle & pop. But Metro now does.
Has anyone else had this misfortune from installing the latest Quicktime and\or iTunes 7?
Krushzone
Postby Jerm » Mon Oct 23, 2006 11:24 am
What is your setting in digital audio:device options:Audio Buffer Packet Size?
What machine are you running? What version/flavor of Metro?
re: Metro snap, crackle, pop
Postby Krushzone » Tue Oct 24, 2006 6:11 pm
Jerm wrote:What is your setting in digital audio:device options:Audio Buffer Packet Size?
Audio Buffer Packet Size: 1024 - 23.2 MS
Machine Name: Mac mini
Machine Model: PowerMac10,1
CPU Type: PowerPC G4 (1.1)
Number Of CPUs: 1
CPU Speed: 1.25 GHz
L2 Cache (per CPU): 512 KB
Memory: 512 MB
Bus Speed: 167 MHz
Boot ROM Version: 4.8.9f1
Mac OS X 10.4.8 Build 8L127
Metro 6.3.6
Krushzone
Postby Jerm » Tue Oct 24, 2006 6:42 pm
Do you have any tracks assigned to 'internal' instruments? Have you experienced this problem directly after rebooting and before running any other apps?
I have 10.4.8 and Quicktime 7.1.3 but it is on a MacBook pro. 6.3.7 willl most likely alleviate this problem although it still should not happen. You may be running out of memory if you are running other apps or networking software.
Postby Krushzone » Wed Oct 25, 2006 5:45 am
Jerm wrote:Do you have any tracks assigned to 'internal' instruments? Have you experienced this problem directly after rebooting and before running any other apps?
- No.
- Rebooting, etc. not relevant.
The event that occured to cause this is exclusively the installation of the latest Quicktime and iTunes 7. Nothing else has changed.
These are not "hiccups", or "hesitation". Just Pops and Snaps occuring during otherwise smooth audio playback.
Krushzone
Postby Jerm » Wed Oct 25, 2006 8:37 am
Try reselecting your audio device in digital audio setup and digital audio device options.
Does this happen on all audio files or soft-synths? when playing back in the jukebox?
re: snap, crackle, pop
Postby Krushzone » Wed Oct 25, 2006 10:32 am
Jerm wrote:Try reselecting your audio device in digital audio setup and digital audio device options.
I have tried changing audio devices, to no avail. Whether I use my trusty Behringer FCA202 audio breakout box, or remove that professional device, reboot, and simply plug headphones directly into the standard Mac mini 1/8" jack, I still hear the random crakle-pops during playback. It is as if the latest Quicktime has changed some deeply rooted core audio processing behavior. I would simply "uninstall" the latest Quicktime if possible.
Yes all audio files. Sorry not familiar with soft-synth or jukebox.
Krushzone
Postby Jerm » Wed Oct 25, 2006 10:49 am
Go to the jukebox window and from the first popup select a folder has MP3's and AIF's in it. Then press play.
re: snap crackle pop
Postby Krushzone » Wed Oct 25, 2006 8:19 pm
Jerm wrote:Go to the jukebox window and from the first popup select a folder has MP3's and AIF's in it. Then press play.
OK, thanks. All sounded good. No snap, no crackle, no pop.
Krushzone
Postby Jerm » Wed Oct 25, 2006 10:25 pm
Well I am curious then. What is it you are trying to play back?
If you start with a new document and then drag one of the files that plays fine in the jukebox over to the graphic editor and then press play does it still play fine?
Postby Jerm » Wed Oct 25, 2006 10:27 pm
It may be that you have conflicting automation in your document or something like that. Perhaps you should create the smallest possible document that exhibits the problem and then email me a Metro Bundle file document.
