Sagan Technology Metro • View topic - Can't hear through my MAC when inputting/digitizizing audio
Postby SongORoland » Thu Sep 28, 2006 2:55 am
I'm transferring my analogue tapes to digital through Metro.
Input and output seem to be working okay, but not during the recording.
In doing so, everything is fine, except I can't hear the audio as it's inputting into the computer (Using Line-In, which looks fine -- shows movement when looking at the volume bars in System Preferences/Sound/Input/Input Level).
After it's grabbed, it's no problem. I can play the grab and I can hear it coming through my computer speakers.
Is there a way to listen when recording through the Line-In?
Thanks.
SongORoland
Postby Jerm » Thu Sep 28, 2006 8:55 am
If you have the full version you can use software audio through. In any case, an external mixer is recommended for monitoring.
Postby SongORoland » Fri Sep 29, 2006 11:20 pm
When you say the 'full version' you mean the top version?
I have Metro SE 6.3.5.5
Software audio thru does not exist for this then. I looked on the following page and my menu does not match that one.
http://www.sagantech.biz/support/switch ... ware-47857
That's fine. I can listen externally.
Thanks.
SongORoland
Postby Jerm » Sat Sep 30, 2006 9:17 am
Yes, we have 3 Metro products, SE, LX and the full version.
Users browsing this forum: No registered users and 27 guests
