Sagan Technology Metro • View topic - Metro 6 OSX - must rrestart after recording audio...
Postby mlm » Sun Feb 20, 2005 12:54 am
Metro 6 OSX - recording audio seems to cause tcp/ip to drop the ehternet connections ip address. must restart.
mlm
Postby Scoot » Sun Feb 20, 2005 2:32 am
Which OS? Panther? 10.3.?
Which Metro? Full? SE? LX?
Version 6.1 or the latter 6.2.4 type?
Midi or Audio interface connected in your setup through USB?
I've never found Metro to drop any ethernet connection.
Usually I can sit here.....work with metro and then answer questions without my router giving me any idea its gone offline.
Postby mlm » Sun Feb 20, 2005 1:36 pm
Scoot wrote:Which OS? Panther? 10.3.?
This only happened (twice, didn't try a third time) when recording audio.
10.2.8, midisport 8x8s, internal audio card, Metro SE.
mlm
Postby Jerm » Sun Feb 20, 2005 3:00 pm
I have never heard of this before. If it is true, then with the very little to go on, I would presume it to be a hardware problem.
Users browsing this forum: No registered users and 17 guests
