Sagan Technology Metro • View topic - scrubbing
scrubbing
scrubbing
Postby almapercus » Wed Jul 07, 2004 8:35 pm
Is scrubbing possible with SE ? I can't find how to do it.
Robert
almapercus
Postby Jerm » Wed Jul 07, 2004 9:26 pm
MIDI scrubbing is possible in the Event Editor by dragging in the left most selection column. Audio scrubbing is not possible in SE or even in the full version running under OS X yet.
I don't want to be misleading though. SE will not have scrubbing even if it is implemented for OS X.
Postby almapercus » Thu Jul 08, 2004 7:53 pm
Thanks, it was explained in the comparison chart. I should have seen this.
However I have no success using the option-R and option-C shortcuts. Is it normal?
Robert
almapercus
Postby Scoot » Thu Jul 08, 2004 9:09 pm
option r - record?
option c - cue?
option r works for me once a track is selected.
cue seems to work ok
(one interesting thing is com/opt r. this should give you the rhythm explorer......which may be unavailable if you have nothing to work with. If thats the case, metro starts recording as if you hit option r, then if you hit stop and com/opt r again, rhythm explorer appears. :wink: )
