Sagan Technology Metro • View topic - Type 0/Type 1??
Type 0/Type 1??
Type 0/Type 1??
Postby chipster » Wed May 19, 2004 8:37 am
I seem to only able to see one track on midi recordings. I send sequences from my Roland that are type 1 and they end up type 0 in metro. When I try and export them as type 1 and then open Metro again they are still type 0. I know it's me but what gives. I'm just an old hippie that is used to audio recording so all this is still a little new. Thanks
chipster
Postby Scoot » Wed May 19, 2004 8:44 am
If you select the one track you see, go to the "EDIT" menu and select "Expand" (with pop out menu) "By Channel".
Probably pays to be in the track window while doing this.
You will probably have to reselect instruments for each midi track afterwards.
Postby chipster » Wed May 19, 2004 9:14 am
Thanks Scoot. learning everyday!
chipster
