Sagan Technology Metro • View topic - Can Metro SE control another internal synth (non VST)
Postby braj » Sun Jan 04, 2004 9:29 pm
I have a friend that has ABsynth and we were wondering if you can set up SE to output a signal to that 'device' without using up the 1 slot available for synths in SE. The app also can be used as a VST instrument. I was wondering if Reason could function in a similar way.
braj
Re: Can Metro SE control another internal synth (non VST)
Postby Scoot » Sun Jan 04, 2004 10:50 pm
braj wrote:I have a friend that has ABsynth and we were wondering if you can set up SE to output a signal to that 'device' without using up the 1 slot available for synths in SE.
I would think not.
You could always record your absynth bits off as audio.
Postby Jerm » Sun Jan 04, 2004 10:56 pm
braj,
What you really want is the full version of Metro. I suggest upgrading.
Barring that then scoot's suggestion makes the most sense. You can always create submixes and archive tracks after. To use more than one synth:
1. Get the first synth track right and convert to audio with mix audio tracks.
2. Remove the synth and add a different synth.
3. repeat.
If you run out of audio tracks. Mix them with mix audio tracks and archive the originals.
Postby braj » Sun Jan 04, 2004 11:55 pm
Yeah, I understand how to essentially 'bounce' the synth tracks now, you just never know what you want to tweak later.
Yeah, I should get the full version. I just can't swing it right now, my wife barely understands the $69 and the $100 more for an Oxygen8. I'm really constricted, so I'm trying to make the most of SE through workarounds.
I'm incredibly impatient though, so who knows. You won't have a 'Spring Sale' or anything, will you? 8)
braj
Postby Scoot » Mon Jan 05, 2004 1:27 am
braj wrote:You won't have a 'Spring Sale' or anything, will you? 8)
I will try and twist Jerm's arm and get you $1 off but I can't promise anything. :lol:
Postby braj » Mon Jan 05, 2004 1:32 am
$1 off
That should help!
braj
Postby braj » Mon Jan 05, 2004 2:40 am
I'm a software QA lead as my profession, I wonder if I could do work/trade on alpha/beta builds for an upgrade? Just a thought.
I just better start saving my pennies. All in all, Metro is a great value and well worth the full version's cost.
braj
