Sagan Technology Metro • View topic - How stable is 6.1?
How stable is 6.1?
How stable is 6.1?
Postby braj » Thu Jan 01, 2004 11:46 pm
I just bought Metro the other day, and am using 6.08. Should I start using the 6.1 pre-release, or are there stability problems?
braj
Postby Jerm » Thu Jan 01, 2004 11:59 pm
As far as I know it is more stable than 6.0.8! :)
Postby braj » Fri Jan 02, 2004 12:08 am
ok, downloading it now... :D
braj
Postby Scoot » Fri Jan 02, 2004 1:16 am
If you have a crash it will probably be due to a plugin with odd programming that makes metro hiccup.
