Sagan Technology Metro • View topic - Metro SE uses Classic???
Postby snuffy51 » Fri Feb 21, 2003 2:17 pm
Does the Metro SE program use Classic or X? I downloaded the Metro 6 demo and it works great. I don't need all the functions however and would prefer to purchase the less expensive SE as long as it runs in 10.2.4. I still have the original Cakewalk Metro SE on system 9.
snuffy51
Postby Jerm » Fri Feb 21, 2003 2:27 pm
Metro products do NOT run under classic. OMS is not compatible and Metro will not run in classic mode. Metro and Metro SE are both native OS X applications (machO) and CFM applications (native OS 9 application type). Double clicking on the application icon will run the appropriate application depending on the current OS
