Sagan Technology Metro • View topic - Metro LX El Capitan ( 10.11 ) compatiable ?
Postby w » Sun Oct 11, 2015 7:01 am
Yes ?
No ?
w
Re: Metro LX El Capitan ( 10.11 ) compatiable ?
Postby Jerm » Wed Oct 14, 2015 11:39 am
We should know in a couple of weeks or so. Stay tuned to this thread.
Postby Jerm » Fri Oct 16, 2015 5:06 pm
Well I installed El Capitan and from a quick pass it does look like Metro 7.2.6 is compatible. I was able to get into a state where I thought the on-screen keyboard was not working but I think it was user error. The on-screen keyboard will not work if a text field is enabled in some other window. When I went back and tried again it appeared to work fine.
Postby w » Fri Oct 16, 2015 5:59 pm
Thanks for the update.
OK then I will unleash Metro LX to run in El Capitan and let you know about any problems/glitches since as i am slowly learning there are some glitches in El Capitan.
w
