Sagan Technology Metro • View topic - How to delete a MIDI track?
Postby Fred » Sat Feb 15, 2003 12:08 pm
i have a MIDI file (type 1) with 3 tracks imported and want to delete the second track. Selecting the track and "cut" makes it empty, but after export and re-import the track is still there, named "Untitled". How can i *delete* this track?
Fred
Postby Jerm » Sat Feb 15, 2003 12:45 pm
Use the Delete Tracks command from the edit menu.
Postby Fred » Sat Feb 15, 2003 2:36 pm
"Delete Tracks" gives me the same result like "cut": after export there is an empty track named "Untitled".
Fred
Postby Jerm » Sat Feb 15, 2003 3:00 pm
Fred,
If the problem is that you have track 1, track 2 (that you want deleted) and track 3.
Then you need to drag track 2 down to track 3 and then delete it. To drag track 2 down, grab its number in the tracks window and drag down.
'Untitled' appears in the graphic editor even if the track does not exist.
Postby Fred » Sat Feb 15, 2003 3:44 pm
Great! That works. After having tried out most of the MIDI and Audio functions let me say, that i am really impressed by the powerful and handy system.
Fred
