Sagan Technology Metro • View topic - LX and Outputs
LX and Outputs
LX and Outputs
Postby GSpro » Fri Mar 10, 2006 12:09 pm
Hi
Just wondering why LX does not retain the outputs assingned. What I did I have assigned all outputs to the SC-8850 and everytime I launch LX it defaults to the 828mkII.
Now last night I installed Metro 6.3.5 full version and it defaults to the SC-8850 and I just launched the app I did no settings of anykind.
Could this be a bug in LX 6.2.2.1 and the Pre-release?
Any response is greatly appreciated
Thank you
GSPro
GSpro
Postby Jerm » Fri Mar 10, 2006 12:20 pm
Get all your outputs like you want them and then save preferences.
Postby Scoot » Sun Mar 12, 2006 3:15 am
If you're using Metro Full, I would throw LX away and just keep the archive available if you wanted it..........actually if you've gone to Full I suppose technically (and copyrightly :lol: ) LX is void anyway.
- Best to have all your hardware plugged in
- Make sure the mac can 'see' everything attached - Audio/Midi Setup of OSX
- Launch Metro and check the midi setup for record to and from [devices]
- Allocate all the outputs and busses you want for a particular setup
(even better if you're not going to use QT/internal have the new outputs REPLACE EXISTING ones from startup prefs......you can always add more from the option in the SPECIAL menu [control Y] to any of the available devices)
....and as suggested do the "save" on the prefs to retain everything.
You could always save a blank doc as a piece of stationary.
Taken from another topic............
You could even go a step further and once you have all the tracks, Virtual instruments and everything else setup the way you want, save and name the file with an extension of .msd for metro stationary document. Then whenever you open that document everything will be the way you want it and there is no danger of saving over it because when you save, SE will prompt you for a new name
