Hello forum, hello Jeremy if I may call you by your first name.
I have some questions but before I go any further I'd like to say:
I purchased MetroLX on Saturday I've been running it for about 10 Hours without a crash or a glitch, something that DP could not do. I'm very impressed at the small footprint of the application itself, memory usage and speed. Just out of this world. I thought apps like this were no longer built this small anymore. My compliments to the programmer(s).
Now back to work. I need some answers
#1 Is it possible to display the Instrument Name in the Mixer Window?
In the Track Window I'm able to type the Instr.Name in the Name Column.
#2 When I first open a Midi file in the Track Window, lets say I only recorded 5 Tracks,
Is it possible to delete the other 43 left unused in the Track Window?
I figured it out how to do it in the Mixer Window.
#3 How to display the actual Instrument Name in the PGM column?
According to the Manual, point and click should see the Instr. Name, instead I get Inc. or Dec. number. In the Bank Column I should only see Variation #. Is that correct?
I have opend the .ins files for the SC-8850 and saved it in the Program folder.
Did I miss something somewhere?
#4 In the Graphic Editor lets say I want to create a fade at the end of a song with either CC 7 (Volume) or using the (Expression) CC 11 is there a way to draw that manually?
If so, how?
BTW I strictly use midi
Many thanks in advance
