Sagan Technology Metro • View topic - removing soundfont banks
Postby Scoot » Fri Dec 09, 2005 6:53 pm
Is there a way to remove soundfont bank names from the popup menu without starting again?
If you delete it from a track the names remain.
There are about 5 soundfonts here though the are named the same way.........but there was only one or two still on a track when the snap was taken.
It's up to the soundfont author to name them......... correct?
Postby Jerm » Fri Dec 09, 2005 8:08 pm
Looks like a bug. :oops:
Postby Jerm » Fri Dec 09, 2005 9:02 pm
This will be fixed in 6.3.3.
Postby Scoot » Fri Dec 09, 2005 10:34 pm
Jerm wrote:This will be fixed in 6.3.3.
Thankyou. :)
Users browsing this forum: Google [Bot] and 11 guests
