Sagan Technology Metro • View topic - Automation Trouble
Automation Trouble
Automation Trouble
Postby sgrocott » Sun Mar 16, 2003 12:33 pm
I am in automation hell ;) some how I have enabled it and now I would just like to erase all the recorded automation in the instruments window.
help!!
Scott
sgrocott
Postby Jerm » Sun Mar 16, 2003 2:35 pm
Scott,
All automation for effects can be erased by ctrl-clicking on the name of the effect in the effects window and selecting clear all automation. If the automation is in the form of Controller 7 & 10 (volume and pan) then you need to go to each track to remove this data. Alternatively you can disable automation playback by clicking the play button in the instruments window.
If I had more info I could probably be of more assistance.
Postby sgrocott » Sun Mar 16, 2003 2:43 pm
Kudos! Jeremy!!
Automation hell in the past. :) Worked great.
Thanks bro
Scott
sgrocott
Postby sseaton » Fri Apr 25, 2003 3:32 pm
Thanks for the tip...
Now how do you erase the automation for the master fader? (I'm using SE)
sseaton
Postby Jerm » Fri Apr 25, 2003 3:44 pm
Section event editor.
Postby sseaton » Fri Apr 25, 2003 11:56 pm
Thank you!
sseaton
