I have a couple of questions before i consider using metro or one of it's lower models.
I have a Tascam FW1082 firewire audio interface and motories control surface. Will this work with Metro as a control surface ? If so is it easy to setup?
I also own a Yamaha Motif ES7 Keyboard which I use as a controller and as my main sounds. How does Metro deal with patches for a unit like this that has over a thousand sounds.
I like patch names to be visiable bank name and numbers mean nothing I have to have names and it done simply.. actually i like everything clean clear and simple. Cubase is the closest I have found so far.. I have tried Logic and hated it cause i couldnt get my head around it. and Tried Digital performer and again it is too complicated.
Thanks I will try the demo if these 2 things are doable
