Sagan Technology Metro • View topic - How To Save ?
How To Save ?
How To Save ?
Postby françois » Fri Sep 16, 2005 9:39 am
hello,
I use to save my files " as a portable bundle in my audio folder, like that I keep Metro file, and audio files in the same folder.
but each time I quit, metro asks me to save again, in a normal mode that create a lot of " .OVV " Files.
would it be possible to enable this question at each session end ?
Postby Jerm » Fri Sep 16, 2005 1:38 pm
I am not sure what you mean. If you save as portable bundle then you do not need to save any other way.
Postby françois » Fri Sep 16, 2005 3:08 pm
yes I know that, but when I quit ( after having saved as bundle ).
metro askes me if I want to save in the normal mode.
If I answer "yes" by error, a lot of ".OVV" files appear on my folder.
Postby françois » Fri Sep 16, 2005 3:11 pm
would it be possible to have a shortcut ?
When I open my metro folder ( bundled ) it always askes me to specify default folder for audio files. the temporary folder is not in the same place than the definitive ?
