Sagan Technology Metro • View topic - Input Hardware error?
Postby Adrian Delso » Fri Jul 22, 2005 6:35 am
I powered everything up yesterday, after a long layoff, imported an audio file, pressed "Play" and got the above message. The cursor was moving, the waveform was visible, but no sound.
I then booted up Logic, imported the audio and it played perfectly - same computer, same interface/soundcard.
Any ideas why?
Adrian Delso
Postby Jerm » Fri Jul 22, 2005 10:05 am
Sounds like you need to visit the digital audio dialog and specify the correct audio device.
Ta, J.
Postby Adrian Delso » Tue Jul 26, 2005 7:13 am
Did just that, everything looked as it should, clicked OK and, as expected, it worked beautifully.
I think I now feel safe to put Logic on Ebay!
Adrian Delso
