Sagan Technology Metro • View topic - Master fader volumn?
Postby Biffer » Wed Jun 15, 2005 7:59 pm
How do I record the master fader volumn...and do do I get rid of it? I knows that I can do the channel faders in the graphic editor but I can't find the master.
Biffer
Postby Jerm » Wed Jun 15, 2005 8:43 pm
If you have the full version of Metro you can select mast fader automation graphically by selecting it in the graphic editor as you would a track.
If you have SE you can see all Master fader automation as text events in the Section Events Editor. To automate master fader in SE (or any version) go to the mixer window enable the record automation button, press play and then move the master fader during playback.
Postby Biffer » Thu Jun 16, 2005 8:04 am
I have the full. Sure enough...there is that little baby sitting off there to the left.
Thanks.
Biffer
