Sagan Technology Metro • View topic - Upgrade to OSX4
Upgrade to OSX4
Upgrade to OSX4
Postby jukehouse » Fri May 20, 2005 6:33 am
I'm currently running Metro 6.3 under OSX3.6
I just got a copy of OSX4
Should I anticipate any problems running Metro when I install the upgraded system ?
jukehouse
Re: Upgrade to OSX4
Postby Jerm » Fri May 20, 2005 9:24 am
jukehouse wrote:Should I anticipate any problems running Metro when I install the upgraded system ?
No.
The only thing that may be a problem is that spotlight will whirr your hard disk for quite a while until the indexes are completed. This competes for hard drive throughput.
Re: Upgrade to OSX4
Postby murphy » Sun May 22, 2005 1:10 pm
jukehouse wrote:I'm currently running Metro 6.3 under OSX3.6
No problems here with TIGER and my Metro SE or Metro LX.
In fact I find TIGER to be more robust although at the moment there seems to be some hard ware issues. For example, I am still waiting for M-Audio to update there driver for my M-Audio USB MIDISport 8 x 8 midi interface box.
Jerm's comments about Spotlight are true. You may find it best to reset the Spotlight preferences and limit what Spotlight will search/update.
For me here I've set Spotlight to search/update just applications on the hard drive I am working from.
murphy
