Sagan Technology Metro • View topic - Modify Instruments and Busses...
Postby Adrian Delso » Mon May 09, 2005 12:53 pm
I downloaded the "I don't like reading manuals" guide to installing effects, etc. from the Sagan site and although it is very clear, it's raised a few more questions:
- it seems to deal exclusively with creating a bus to for effects for audio ; what about MIDI and software Instruments?
- when I look in the Special menu, it refers to Modify Outputs and Busses and not Modify Instruments and Busses (is that because I'm only running the demo version of Metro 6?)
- are the Apple effects accessible to any software sequencer? I've got them on busses in Logic.
Sorry if these are too dumb, but I can't find specific answers and I need them if I'm going to buy the product. :D
Adrian Delso
Re: Modify Instruments and Busses...
Postby Jerm » Mon May 09, 2005 1:06 pm
Adrian Delso wrote:- it seems to deal exclusively with creating a bus to for effects for audio ; what about MIDI and software Instruments?
It is pretty much the same. You can select a software synth from the graphic editor popup.
Adrian Delso wrote:- when I look in the Special menu, it refers to Modify Outputs and Busses and not Modify Instruments and Busses (is that because I'm only running the demo version of Metro 6?)
The term "instrument" was changed to "output" a while back because it is more appropriate.
Adrian Delso wrote:- are the Apple effects accessible to any software sequencer?
All sequencers that support AudioUnits (AU's) under OS X only.
Postby Scoot » Mon May 09, 2005 3:28 pm
The instruments name became outputs which helped define what they were.....as most of the time you're thinking I've got this 'thing' where am I going to hear?.....through an output of course.
The mixer window used to be called the instrument window.
That is why it uses the command I to bring it up and this was retained as command M was for markers.
As far as effects or VSTi's are concerned you have 2 options.
Sticking it onto an aux or sticking it directly onto the track you want it on.
All beginners would probably go for the 'on the track' option.
Originally you would select your track
Hit command 9 and command zero to bring up the plugins and effects windows, and drag the plugin needed to the effects/synth window.
Now as Jerm says you can choose something directly out of the graphic editor window.....but this operation is still moving the plugin to the effects window (it's doing it for you).
The aux is there to allow you to run an effect like a reverb on more than one track thus saving CPU......as you don't need to run multiple instances of it.
Changes like the instuments to outputs or instuments to mixer names and accessing synths from the graphic editor are mostly forum requests that Jerm has taken on board and worked his guts out to implement.
(The one he sweated the most over was multiple undo! :lol: )
If you can think of other things Metro needs suggest them and he'll probably put them in within 30 days............he's a bit of a genie. lol
Many thanks
Postby Adrian Delso » Tue May 10, 2005 3:35 am
I love this Forum - constructive responses and no put-downs.
My thanks to you both.
Adrian
Adrian Delso
