Sagan Technology Metro • View topic - different controllers
Postby niro » Thu Nov 11, 2004 4:50 pm
if i have multiple instruments i want to control with midi but their controllers aren't standard, how can i keep track of the controller names without having to memorize numbers per instrument? for example, if i have a synth where controller 25 is "octave select" and another where controller 25 is "waveform select" how can i assign that info? i tried using "favorite controllers" but it only allows me to have one static group of controller names per session.
niro
Postby Jerm » Thu Nov 11, 2004 7:25 pm
Controller assignments are tied to program name banks. Create a new program name bank and then assign controllers at will. Remember to save preferences (and/or to a .ins file) to make the changes permanent.
Postby niro » Fri Nov 12, 2004 5:32 pm
i tried this but it seems program names cannot be edited from the "Program Names" dialog after clicking "New" or opening and editing an existing .ins file (i guess i should file a bug). however i manually wrote the .ins textfiles i needed and metro read them just fine, and assigning controllers by program name works great.
niro
Postby niro » Fri Nov 12, 2004 5:34 pm
niro
Postby Jerm » Fri Nov 12, 2004 5:49 pm
Program names editing works fine. After clicking new and then edit, you need to click on the double dash and then wait a few seconds in order to edit them. This part of the program uses Apple's standard text browser and that is just the way it works.
Postby niro » Fri Nov 12, 2004 6:19 pm
yeah single click. i'm a metro newbie!
niro
