Paul wrote:...activity monitor that can be found in the Applications/Utilities folder.Why is it not telling 'the whole story'? What do you mean by that?
Well, if you check out activity monitor while clicking in a menu you will see that it reports Metro uses 100% of the cpu. This is because, at the current time, Metro does not use carbon-events fully and uses the older event model. This is because of added compatibility. In the future Metro may move to carbon-events.
Activity monitor also and more importantly, does not tell you how much of the cpu is being used in an audio's real-time task which is the most crucial for audio applications since this runs at a higher priority than UI types of tasks.
A much better program for determining real-time usage is Apple's Shark which is part of the CHUD tools.
