Sagan Technology Metro • View topic - Error code -1309
Error code -1309
Error code -1309
Postby Jazzdude » Fri Jun 11, 2004 9:05 pm
I've been trying to save a file as a portable bundle, but every attempt is unsuccessful and returns the error code -1309. What is this?
Jazzdude
Postby Jerm » Fri Jun 11, 2004 9:31 pm
I looked it up and it appears to be fileBoundsErr....
/*file's EOF, offset, mark or size is too big*/
EOF means "end of file" so perhaps you have reached the 4 GB limit?
How many audio files do you have and are they big? Do you have video? Have you tried deleting a few tracks or saving as a compacted bundle?
Postby Jazzdude » Sat Jun 12, 2004 5:35 am
Saving as a compacted bundle worked. Thanks!
I had never used this command. I was not aware of it until yesterday!
This is a very large project containing around 150 audio files.
The entire project folder is 2.19GB.
Jazzdude
Postby Jerm » Sat Jun 12, 2004 8:39 am
Saving as a compact bundle is very useful as it saves the minimum audio to reproduce the current file but beware that only exposed regions of audio are saved so you will not be able to expand regions by dragging them like you could with the original file.
Postby Jerm » Sat Dec 31, 2005 10:16 am
HFS limits the file size to < 2 GB. HFS + is higher.
Users browsing this forum: Google [Bot] and 16 guests
