Sagan Technology Metro • View topic - Easy way to put main volume controller to 127?
Postby françois » Wed May 12, 2004 11:37 am
ok scoot thanks.
could you give me an easy way to put main volume controller of few tracks at 127 ?
I have a midifile with a main volume controller who goes progressively to 0 and I want him always at 127, but I don't want to use the pen..
Do you've got an easy solution ?
Postby Jerm » Wed May 12, 2004 12:13 pm
The easiest way is to move the fader to 127 right (or control) click on it and select replace automation.
Postby Scoot » Wed May 12, 2004 8:07 pm
Turn off automation? :lol:
A new trick learnt there.
Use Jerm's solution.
I used to go to the graphic editor and do a select all and delete on the data.
Postby Jerm » Wed May 12, 2004 9:05 pm
Although my solution is 6.2 only I believe.
