Sagan Technology Metro • View topic - rewind to the firste measure
Postby françois » Wed May 12, 2004 8:12 am
Could you tell me if it's possible to automaticaly go to the first measure one I change to song in the section window ?
for example I'm playing the song N° 50, and I stop at the meas N° 32. If I change of song , the N° of the bar stays at 32 instead of move to N°1..
thanks
Postby Scoot » Wed May 12, 2004 9:46 am
The only thing I can think of is copy and paste (or save off) your 50 measure song below the other songs and then shorten the original 50 down to 32 with delete time.
This way once it finishes 32, it will go on to the next song from the start.
This would be for live performance.
If you were just working with the tunes then when you hit stop, hit rewind and then go to the next tune.
I thought sections were to change bars and create variety within a song.
Play 4 bars of this
now 6 bars of this
build a bar or two with a fill
8 bars of the second part again
and so on.
scoot
