Paul wrote:If I set the output of track 1 to 'Hardware device', I should hear the main buss (well, outputs 1 and 2) of Reason, right?
Paul wrote: Or is it necessary to select a separate track for every Reason instrument?
Paul wrote: I can see that midi is being transfered, but no audio...
Paul wrote: What if I create a new document in Reason (V. 2.5), then don't create a mixer, create a Subtractor synth and select Subtractor as an output on track 1 in Metro. Should I hear a sound? Because I don't... Again, I see that the Subtractor is receiving midi.
Paul wrote: Is my perception right that EVERY sound created by Reason is routed to the one aux bus in Metro?
Paul wrote:So I can't choose, for example, outputs 63 and 64 of the hardware device? I know this is possible in Logic.
Paul wrote:Creating outputs for different Reason instruments on separate tracks is only needed to send midi data?
Paul wrote:I guess I'm having a hard time understanding the concept of rewire implementation in Metro.
