Sagan Technology Metro • View topic - Using Keyboard when Auditioning sounds
Postby lplplpx3 » Fri Mar 05, 2004 1:47 am
When the "Select sound for channel" pop is open, is the only way to hear the instruments by using the on screen keyboard? My USB board will not play the sound until I close the pop-up.
lplplpx3
Postby Jerm » Fri Mar 05, 2004 2:14 pm
Although I am not too sure what you are asking I am confident that you will not have this problem if you use the DLS musicdevice instead. Check the answer to your other post.
