Sagan Technology Metro • View topic - Up grading from Metro to Metro G4
Postby kaboombahchuck » Tue Mar 02, 2004 7:37 am
OK, so I have finally decided to take the kid gloves off and put the G4 version into the G5. I have downloaded the pre-relese 6.1.0.9 G4 version. I currently have the regular 6.1 installed... do I just install the new G4 version and rock on? Also, sould I just delete the other versions I have on the computer, or are they needed?
kaboombahchuck
Postby Jerm » Tue Mar 02, 2004 2:44 pm
Yes. Just install the G4 version. You should remove (or archive) the other versions if you want to be able to double click on documents and have them launch the correct version of Metro.
