Sagan Technology Metro • View topic - Cue Loop seemingly not persistent
Postby fastlanephil » Sat Nov 29, 2003 1:37 am
When I launch Metro the cue loop and record loop buttons are always turned on. This confused me at first when I tried to record a little piano and could only go for eight bars. I thought I had accidentally turned them on but they are active every time I launch Metro. If you don't see it maybe it's my Midiman or Transit drivers.
I had to unplug the Midiman 2X2 before plugging in the M-audio Transit to get a connection. But I do have software audio thru working, though with a little latency.
Postby Jerm » Sat Nov 29, 2003 2:33 pm
Phil,
I believe these are restored to the state they were when preferences were saved. Try:
1. turning off cue-loop / record-loop
2. saveing preferences
3. quitting and restarting Metro
They should now be off when you start up.
Cue&record loop buttons
Postby fastlanephil » Sun Nov 30, 2003 1:59 am
That was it.
Thanks!
