Sagan Technology Metro • View topic - I have an iBook 700 MHz and a Midiman 1x1...
Postby sseaton » Wed Feb 19, 2003 10:28 am
I would like some advice on buying Metro. I want to do basic MIDI work with the built in QuickTime synthesizer. I would like to also record maybe one audio track... and be able to monitor it through headphones while listening to my MIDI tracks. Nothing fancy.
I have an iBook 700 MHz and a Midiman 1x1. I have successfully used Intuem, but that is a sequencer only... and a pretty crappy one for my purposes. I also realize that I will need an iMic or something to get audio in to the iBook.
My question: Can I use my setup for what I described? I'm most concerned about monitoring sounds while I record them through the computer's headphone jack. Like I said, I can do this in Intuem, but I'm not sure if this will work in Metro.
Thanks!
Sean Seaton
sseaton
Postby Jerm » Wed Feb 19, 2003 2:14 pm
You should definitely be able to monitor quicktime sounds (internal) with the headphones. You may have problems with the IMic because it a USB device that uses the built-in apple USB driver and as such, the input has no knowledge of the output and visa versa. This makes play-thru virtually impossible.
Users browsing this forum: Google [Bot] and 17 guests
