Sagan Technology Metro • View topic - importing lyrics
importing lyrics
importing lyrics
Postby françois » Fri Sep 26, 2003 1:19 pm
could you tell me how can I import lyrics ( .txt / .doc ) in metro ?
Postby Jerm » Fri Sep 26, 2003 1:25 pm
The only way (right now) to do that I believe would be cut and paste.
Postby françois » Fri Sep 26, 2003 1:56 pm
I tried, but nothing appears
Postby Jerm » Fri Sep 26, 2003 2:26 pm
Worked fine for me.
Paste into the lower section of the lyrics window. You then need to select the track and position and click the apply changes button. Use the show/hide positions button to show position and arrange the lyrics position on the staff if necessary.
Postby françois » Fri Sep 26, 2003 3:33 pm
in " special " , looping uses the same shortcut than "lyrics "
high haroww + command + L
Postby Jerm » Mon Sep 29, 2003 9:42 am
Thanks. This is fixed in 6.1.0.1.
