[I would have posted this in the OS X Audio Forums, but they've been down all day.]
Is anyone else having a problem w/ MIDI services going out of whack? 3 out of 4 times when I try to boot up a MIDI app, I get an error to the effect that MIDI services could not be established.
• If I boot up Audio MIDI Setup, the MIDI Devices tab says "MIDI Setup is Empty";
• Metro's error message says "-10839: MIDI Server start error couldn't start the server",
• and MIDI Monitor says "Error: There was a problem initializing the MIDI system. To try to fix this, log out and log back in, or restart the computer."*
Booting up Process Viewer reveals multiple instances of a process called MIDIServer, one for each time I tried to boot up a MIDI app (even if I've closed out of the apps - if this was working properly, of course, MIDIServer would quit once the apps that need it quit). I can force-quit each of these (although it normally takes two or three force-quits before they go away), but the only chance I have of actually getting a MIDI app to work is to reboot the computer - logging out and back in will not work.
I have tried:
1) Creating a new user to see if something in my usual account got munged.
2) Running Disk Utility, both from the startup disk and the installer disk (doing both repair permissions and repair disk).
3) Uninstalling each MIDI driver I have installed and reinstalling them individually.
4) Reinstalling Jaguar via Archive and Install.
and every permutation of the above steps I could think of. Still no luck - once MIDI services have crapped out, the only chance I have of getting it to work again is restarting, and even that only has a 25% chance of working. If I can get MIDIServer up and running, Metro SE is a joy to work with under OS X, but it's getting there that's making me lose what little hair I have left. A reasonable workaround would be a way to re-initialize MIDIServer w/o having to reboot the whole machine.
My setup:
B&W G3 upgraded w/ an XLR8 G4/500, running OS X 10.2.4
Roland SC-8820 connected via USB (most recent drivers)
Tascam US-428 connected via USB (v. 3.20 beta drivers)
Opcode MIDI Translator II connected to a gPort Serial adapter (most recent beta drivers)
BTW, this started in 10.2.3 two days ago (hadn't done much in MIDI before, other than boot up Audio MIDI Setup and MIDI Monitor just to verify that things seem to have worked), and I upgraded to 10.2.4 at that point to see if that would fix things. And, yes, my first guess was the beta drivers for the MIDI interfaces, but this problem happened w/ no drivers installed at all after an Archive & Install of Jaguar, in a brand new account.
Any suggestions?
Evan Evanson
*is that a great, informative dialog box, or what? Three cheers for Kurt Revis.
