Sagan Technology Metro • View topic - Change Ports dialog.
Postby fastlanephil » Wed Aug 13, 2003 11:06 pm
Every time I open a file the change ports dialog comes up with my port settings on the left in brackets. Do I need to do something to eliminate this.
Postby Jerm » Thu Aug 14, 2003 12:17 am
OS X?
Did you modify your studio setup document?
If yes, then what has happened is the unique identifiers for your MIDI ports have changed. The only 2 ways I can think of right now to overcome this is:
1. Restore your studio setup document.
2. Re-Save your files after changing your ports correctly.
