Sagan Technology Metro • View topic - Jukebox
Jukebox
Jukebox
Postby Scoot » Fri Jun 13, 2003 10:53 pm
Trying to grab an aiff and mp3 from a folder where the aiff and mp3 are the only things in the folder. When I go to play them metro says "-50 Error in parameter list / Not an existing volume, and no default volume/ Bad positioning information / bad drive number".
is it metro or my start up disk at fault?
Postby Jerm » Sat Jun 14, 2003 10:49 am
I do not understand. What does "grab an aiff and mp3 from a folder where the aiff and mp3 are the only things in the folder." mean?
Postby Scoot » Sat Jun 14, 2003 5:32 pm
A general term for - Add files from folder.
(If I were to download a new driver for something I would be grabbing it off the net :) )
I made sure there were no other files or files types in the folder I chose because if you were to just add files from your total hard disk you end up with a bunch of funny resources included in the list.
Postby Scoot » Sat Jun 14, 2003 5:50 pm
Here's a picture of what happens when I press play....under OSX and OS9.
Postby Jerm » Sat Jun 14, 2003 5:51 pm
It sounds like you have funny characters in one of your paths or folder names. Metro still uses some old Macintosh filename standards in some cases.
Postby Jerm » Sat Jun 14, 2003 5:53 pm
If you ctrl-click on the first item and 'get info'what is the complete pathname?
Postby Scoot » Sat Jun 14, 2003 5:58 pm
I just posted a picture of it........you replied too fast. :D
Actually I've changed the names to 1.aif and 2.mp3 and it still doesn't work for me. Obviously no one else is suffering from it and I was just seeing what the jukebox was as someone pointed me to it.
It's not a big deal.....no worries Jerm.
Postby Scoot » Sat Jun 14, 2003 6:06 pm
Postby Jerm » Sat Jun 14, 2003 6:10 pm
You need to select an instrument from the popup. It is blank in the picture (that is now deleted). This must be an audio instrument.
Postby Scoot » Sat Jun 14, 2003 6:54 pm
HA!
I shot myself in the foot (AGAIN) when I went for a lean set of instruments (midi synth only) when I was mucking around on my Yamaha.
