Sagan Technology Metro • View topic - Modify Instruments and Busses
Postby Scoot » Sat May 10, 2003 9:35 pm
I have ports allocated to my Yamaha synth. Also a few to DSLmusicdevice (lets say 1-4).
If I were to add 16 to the DSL port and say 'replace', why does it clear my yamaha ports? Why can't it just replace the DSL's? :D
I suppose it doesn't recognise words.
ok I can add 12 DSL's starting at 5 and going through to 16.
Can you remove ports individually?
Clicking them with option or shift keys just selects them. Actually shift does have an interesting effect. :wink:
(I'm trying to keep my yamaha ports even though it ain't plugged in right now).
Postby Jerm » Sat May 10, 2003 10:55 pm
Scooterman,
You are confusing me. I think you mean instruments when you say ports. You cannot remove ports except by changing your studio setup document or deleting your synth plug-ins. Ports are collected automagically when your studio document changes.
You can delete instruments from the instruments window.
Replace does what it says... replace.
Postby jonrandall » Tue May 20, 2003 3:40 am
[REMOVED BY AUTHOR]
jonrandall
Postby Scoot » Tue May 20, 2003 5:22 am
instruments sit on ports........was probably my mistake.
Postby jonrandall » Tue May 20, 2003 10:09 am
[REMOVED BY AUTHOR]
jonrandall
Postby Jerm » Tue May 20, 2003 10:11 am
Instruments are configurations and ports are output destinations. So instruments configure where the final Audio or MIDI output is sent.
