Sagan Technology Metro • View topic - Trying to understand LeadGen Scale creation from ChordMarker
Postby Lytz1 » Fri Nov 02, 2018 8:46 am
so I am trying to understand now how the LeadGenerator creates scales from chord-markers.
Sometimes the scales are completely off the rails, sometimes it nails it quite perfectly.
Does the Lead Generator, when it creates ad-hoc scales from the chord-markers, take only the current marker into account,
the neighboring markers as well or all markers in the song (which is unlikely)?
Re: Trying to understand LeadGen Scale creation from ChordMa
Postby Jerm » Fri Nov 02, 2018 11:55 am
I believe it is based on the currently selected markers.
Postby Lytz1 » Fri Nov 02, 2018 12:12 pm
So probably range-selection in the arrangement also does count?
Postby Jerm » Fri Nov 02, 2018 12:26 pm
I don't understand your question.
Postby Lytz1 » Fri Nov 02, 2018 1:56 pm
Well, I usually select a range in the song, never select markers directly.
So this can't be based on selected markers, unless the markers also get selected when a range-selection
is made in the song.
Postby Jerm » Fri Nov 02, 2018 2:06 pm
It is the markers that are within the graphic editor selection.
