Sagan Technology Metro • View topic - LeadGen: Difference between two tracksync settings
Postby Lytz1 » Wed Oct 17, 2018 6:38 pm
Hey there,
short question again about the LeadGen settings:
There are two track sync settings.
One in the marker window and one on the URE Leadgenerator Preset 1 page.
What's the difference between the two?
(Edit: I see that the Tracksync Setting in the Marker Window gives
"absolute" sync. It does exactly what the Guide track does...
But a bit more info would be nice...)
Re: LeadGen: Difference between two tracksync settings
Postby Jerm » Wed Oct 17, 2018 6:52 pm
It works pretty much the same as the other settings in the marker edit dialog. Set in the dialog means that it happens for the duration of the marker. Track sync set in the RE preferences dialog means that it will happen randomly based on the weighting. In the Marker dialog it always happens.
Users browsing this forum: Google [Bot] and 8 guests
