Sagan Technology Metro • View topic - Remote Control Editor (Keyboard assignment...)
Postby Lytz1 » Sun Oct 07, 2018 9:05 am
New topic. This time Remote Control Editor:
I'd like to press a key on my keyboard and send a value to a parameter of a plugin.
This works when using standard CC (like modwheel or others), but I can't get an EFX Parameter
to do anything when it's assigned to a key on my keyboard via the Remote Editor.
Is this not possible or am I doing something wrong?
Also: is it possible to combine a note on my keyboard with a modifier from the list? (i.e. "shift")
(If it's not too much I'd also like to know what "option 1-7" and "mode 1-15" does in the modifiers.)
Re: Remote Control Editor (Keyboard assignment...)
Postby Lytz1 » Mon Oct 08, 2018 6:45 pm
I already figured a lot of things out regarding the Remote Control Editor.
Now I am stuck again. I am now trying to map some buttons to
AuxSelect (+/-)
Can't get it to work. Do you have a receipt for this?
(Also Track Aux Send Volume seems to does nothing. I am looking for a way to bypass the aux dropdown window
all the time when mixing.)
Postby Jerm » Tue Oct 09, 2018 4:47 pm
I will look into this.
