Sagan Technology Metro • View topic - deleting section
deleting section
deleting section
Postby srosenberg » Fri Apr 22, 2016 10:25 pm
In the section window of Metro 7.2 I can't delete a section simply by selecting the section and using the delete key as I could in earlier (7.1) versions of the program. Now it seems necessary to click the section title with the control key and select clear in the submenu
srosenberg
