Sagan Technology Metro • View topic - Way to rename outputs/ports of Instruments?
Postby Lytz1 » Tue Dec 29, 2015 7:08 am
Hey J',
say, is there a way to rename the ports of VSTi Instruments?
I have a lot of duplicated VSTi Instruments (like Battery 3 for example)
and in the Output Dropdown Window on the Arrangement page I get a lot
of 3-1-1, 3-2-1, 3-3-1 suffixes and so on. Thats a bit confusing.
(Especially with Plugins that have numbers already behind them in the first place.
like Kontakt 5, MachFive 3, Albino 3 and so on...)
I'd like to rename theese. However I do not know if this is possible.
Any hints?
Re: Way to rename outputs/ports of Instruments?
Postby Jerm » Thu Dec 31, 2015 12:04 am
You can either option (alt on windows) click the output assignment column in the tracks or graphic editor windows or you can double click the name in the mixer window.
