Sagan Technology Metro • View topic - When Using URE
When Using URE
When Using URE
Postby GSpro » Wed Jan 22, 2014 9:00 pm
Hello,
I just tried loading a String patch from Kontakt 5 and renamed the track Strings. From the "Track Type" in the URE, I can load, Drums, Keyboard, Bass and Guitar and it works, but how do I load strings or any other presets located in the "Presets Folder -> Real Time Arp Presets" to have URE generate different patterns?
Thank you,
Adriano
GSpro
Re: When Using URE
Postby Jerm » Wed Jan 22, 2014 9:35 pm
I think you are confusing two totally separate topics.
The track type determines how URE responds to track data.
RealTimeArp presets are loaded into the Real Time Arpeggiator only. The arpeggiator can be found in the Keyboard window by turning it on. You can then load a preset via the options menu,
Re: When Using URE
Postby GSpro » Wed Jan 22, 2014 9:57 pm
Hi Jeremy,
You are correct! I need to get with the program, here. :lol:
Thank you,
Adriano
GSpro
Users browsing this forum: Google [Bot] and 18 guests
