Sagan Technology Metro • View topic - Rewire Question
Rewire Question
Rewire Question
Postby fastlanephil » Mon Nov 12, 2012 10:09 pm
I see that Metro 6.2 and newer now supports ReWire. I'm a little clueless about the detail of the technology but I read in Wikipedia that the ReWire system consists of Mixers, Panels and devices. It states that an application can act as a Panel/Device or a Mixer and also a Panel/Device and a Mixer at the same time.
I'm wondering what ReWire features Metro has. Can it send MIDI data or does it only receive MIDI data.
Phil
Re: Rewire Question
Postby Jerm » Tue Nov 13, 2012 3:20 pm
Metro works under ReWire as a master. I have gotten requests to make Metro into a slave but if that happens it will not be for a while.
Users browsing this forum: Google [Bot] and 18 guests
