Sagan Technology Metro • View topic - OSX Mountain Lion
OSX Mountain Lion
OSX Mountain Lion
Postby jukehouse » Thu Jul 26, 2012 8:26 am
Anyone know if Metro is fully compatible with OSX Mountain Lion (10.8)?
jukehouse
Re: OSX Mountain Lion
Postby Elmar » Sun Jul 29, 2012 9:57 am
Hello,
i installed Metro 6.5.2 at OSX 10.8.
I get an error "ALOISEN font not installed "
On my system Aloisen is installed and i had no problems
using OSX 10.7..
Need help please!
Elmar
Elmar
Postby Jerm » Sun Jul 29, 2012 3:03 pm
In Metro 6.5.2 a font file named "AloisNew.TTF" must be in the system fonts folder. Usually it is a path like "HD:Library:Fonts".
To be sure you have this font installed. Go to Apple's Font Book program. The font name appears in Font Book as "Aloisen New". If it is not installed then you will see the message you are seeing and notation will not be available.
Did you install in Mountain Lion using the 6.5.2 installer?
I do not have Mountain Lion in house yet but I will post here when I find out anything.
Postby Elmar » Sun Jul 29, 2012 3:29 pm
It works !
sorry that was wrong:i installed Metro 6.5.2 at OSX 10.8.
Metro was installed and it was only an update from OSX 10.7 to 10.8 !
Elmar
Elmar
Postby Jerm » Sun Jul 29, 2012 3:39 pm
Hello Elmar,
I don't understand. Can you please describe the steps you performed to produce the 'missing font' error?
Thanks.
Postby Elmar » Mon Jul 30, 2012 6:15 am
Please excuse my bad english !
I've performed an update of Moutain Lion.
The Metro program, I have not reinstalled.
The fontset I have not changed.
After your hint about ALOISEN-Font I have in the "Zeichensatzverwaltung" (German)
found ALOISEN and NEW-ALOISEN were inaktiv.
I have now idea How that happened?
Then I startet the correction funktion an it worked.
I do not know what happened exaktly?
Elmar
Elmar
Postby Jerm » Mon Jul 30, 2012 12:58 pm
Okay thank you for the explanation.
So I assume the only problem (so far) with upgrading your system to Mountain Lion is that the installed Fonts may be deactivated and need re-activation via Font Book. Correct?
Postby Elmar » Mon Jul 30, 2012 2:08 pm
Hello
I've checked all the features of Metro of course not!
Once there is something new I register in the Forum
Elmar
Elmar
Postby Elmar » Tue Jul 31, 2012 2:35 pm
Another small addition:
There must be enabled ALoisen New.
Elmar
Elmar
Postby Jerm » Sat Aug 04, 2012 2:54 pm
I have done some initial testing and Metro works fine in Mountain Lion. The only problem is Apple. First, in Lion they get rid of the scroll bar arrows and now they won't let anyone install software except through the stupid Apple store. Also Mountain Lion will not install on perfectly good and fast Apple Macintosh computers like the quad core Mac Pro I have. Ironically I have seen it installed on not so fast Windows based PC's using VMWare. I am certainly not an Apple fan-boy at this point.
To Install Metro in Mountain Lion, you must turn off gatekeeper.
Also there is a bug in Metro 6.5.2 that makes some of Apple's Cocoa based plug-ins display wrong. This occurs in Lion as well. This problem is fixed in Metro 6.7 (unreleased as of yet).
Postby fastlanephil » Sat Aug 04, 2012 4:58 pm
The Turn Off Gatekeeper$$$ link is valuable information for many Mac users. This needs to be passed on!
The only solution I have found for the lack of scroll bar arrows in OSX Lion is to use the keyboard arrows but it doesn't work automatically.
Postby Vigner » Sun Jan 27, 2013 4:27 pm
Works great here but there are some AU plugin interfaces that doesnt show in the window when i want to edit them!!
Vigner
Postby Jerm » Sun Jan 27, 2013 6:08 pm
Vigner wrote: but there are some AU plugin interfaces that doesnt show in the window when i want to edit them!!
This is not an issue. Did you see my answer to your bug report/question and did you try the "easy solution"?
Users browsing this forum: Google [Bot] and 18 guests
